Resource icon
Club Car Engine Removal Instructions
HotRodCarts submitted a new resource:
Club Car Engine Removal Instructions - Instructions For Removing a Club Car Gas Engine - FE290
:clubcar:
Club Car Engine Removal:
1. Disconnect battery
2. Disconnect ground wire going to engine(should be on dipstick 10mm nut)
3. Remove 1, 1/2" carriage bolt under starter and the 2, 9/16" mounting bolts. Ty up starter out of the way.
4. Remove muffler clamp around the BIG part of it. Remove 1/2" bolt that bolts the muffler bracket to the engine block. Remove the 2, 1/2" nuts and washers from engine block exhaust port and remove muffler.
5. Remove throttle cable from governor arm...
Read more about this resource...
