Club Car Electric Motor Wont Come Off - Stuck On Rear End
shadowman
What year and voltage? Your sure you have all the bolts out including the bracket underneath? If so you may have to spray around opening and tap tap tap with a mallet or a hammer just be careful. If you get movement than get a screwdriver and work it out. Some motors can be tough but it will come off.
MaxGyver
As I'm in the middle of a motor issue, I assure you it does come out relatively easy if you get all the bolts. 3 at the top and one toward the bottom was what I had on my 1998 48 v Club Car motor. Mine is a series unit so I'm not sure if it makes a difference, but hope this helps. One last thing... go easy on that aluminum casing as it's not too thick. I used a small rubber mallet to tap it lose and then with elbow grease it was no problem to slide it out and off - but the darn thing is also HEAVY.. be ready to grunt a little. LOL. best of luck
