Club Car DS Resistor Coil Setup
Thor264
Hello all,
85 Club Car DS electric golf cart is s when first apply pressure to pedal. Could I have put the resistor coils back in the wrong sequence or could it be something else?
thanks in advance! !
DickB
In the wiring diagram the Speed Switch with the red wire should be activated first as you press the accelerator, and the one with the black wire last. The red wire solenoid is engaging all resistor coils (slowest) and the black none (fastest). Check the connections between the speed switches and solenoids, and/or solenoids to coils.
