Club CAR DS 97 48Volt
coach44
Ok..97 club car DS 48Volt Problem started with reverse working and forward not working with 49.70 Volts available. Just installed 6 new Trojans today..added a 200 AMP solenoid...resister and Diode. New Cables, new J-Rods. Found a Bad Forward Micro switch...replaced it....then found a bad Micro switch in V-Glide as well...walla...Right...? Wrong!! I turn the key on and the Solenoid Clicks and is Active.....I push the Accelarator and the solenoid Deactivates? Help me here what Happened?? where did I make my mistake??
coach44
Ok... found the solution...... I found a bad micro switch in the V....took out a 3 prong which included a NO position and a NC position and a COM Tab. I replaced it with a 2 prong and thats where I made the mistake...ouch...but fixed now!!
Not all micro switches are created equal!!!!!
