club car charge indicator light flashing
RChris57
Hi
I have a club car cart, and the battery charge indicator light is flashing red between the 1st and 2nd bar. I have charged it all night, and it is running fine, but not indicating a full charge, just flashing red between bar one and two. Any clue?
shadowman
not sure but it could be just the gage going bad............have you tested and load tested the batteries? checked water level? i would do these things to make sure batteries are good.......what brand and how old are they? what year and voltage cart......................
golfdog
Had the same problem with an EZGO. Just disconnected the battery terminals, waited 2 mins, reconnected and bob's your uncle all back to normal. Worth a try. Just don't forget to switch to TOW before you disconnect the batteries, if you have a TOW/RUN switch.
