Club Car Carryall Was Running Until I Cleaned Battery Terminals
Kjk
Have 2002 Club Car Carryall electric cart that was running fine until I cleaned the battery terminals. May have switched the positive on the solenoid when reconnecting. According to the manual the solenoid is hooked up backwards. Yellow to the controller is on the outside terminal and the positive from the battery is on the inside. Any help would be appreciated.
Unless there is a diode on the large terminals that should not matter the small terminals are Marked positive and negative
Kjk
The diode is on the small terminals, the large terminals have a resistor that measures within tolerance. The resistor is all crusty looking will replace it when I can get to town.
