Slayerextreme
I have a 96 Club Car with new parts galore and engine can't build any RPM. Here's what I'm working with.
Brand new Kawasaki FE-290 motor.
Brand new Kawasaki Carburetor.
Brand new drive belt.
All new fuel filters and hoses
New air filter
No rev limiter installed
Govenor disabled
Zip Tie on throttle spring
Adjusted pedal to where engine starts after 3/4 inch
Adjusted throttle cable out of the black box to remove all slack
6" lift 22x11x10 Sod Buster Tires
It runs decent until in a bind or climbing any sort of a hill then it bogs down and loses RPM
Motor was weak and smoking so I replaced it and everything that helps one to run...used original carb but new it was filthy so I replaced it thinking that would help with the engine bogging down...helped some but not much...
What settings or adustments am I missing? Is there a way to make an adjustment that allows the carburetor to be opened more???? It apears that only about half the throttle is being opened. I can reach down a pull the throttle cable with my hand past where it goes using just the pedal.
I am just about at my wits end. I have read as much as I can, replaced everything that I could, I just cant get this thing to build any RPM's. This golf cart should be a hill climbing little bugger. At least better than what it is right now....
New air filter
Govenor disabled
