Club Car Battery problem
galetsroll
I had one battery that went bad and changed it out with a new one last night. after changing out the golf cart was real slow, so I figured that I needed to charge the batteries... I put the charger on last night but when I woke up the GFI had activated and the charger was not working.... I checked the fuse on charger and on the batteries both were ok... so I reset GFi and plugged in charger but it keeps tripping the breaker on the charger.... did not have this problem prior to swapping out battery... any ideas or thought would be greatly appreciated.
shadowman
make sure you pyt you batt cable pos to neg ...................
