CHARGING SYSTEM
warrior7946
I WOULD LIKE TO KNOW IF ANYONE KNOWS HOW THE WIRING IS CONNECTED TO THE BATTERY.WHEN I PUT A TESTER TO THE BATTERY IT READS THAT IT IS CHARGING INTO THE BATTERY BUT THE CART STILL GOES DEAD IN A SHORT TIME WEATHER I DO LONG RIDES OR SHORT.I HAVE PUT A NEW BATTERY IN THE CART AND HAVE NO ACCESSORIES TO DRAIN BATTERY.IF ANYBODY COULD TELL ME HOW IT SHOULD BE HOOKED UP I HAVE A HEAVY WIRE FROM THE STARTER / GENERATOR AND I ALSO HAVE A WIRE COMING FROM WHAT APPEARS TO BE THE MAGNETO THANK YOU IN ADVANCE CLIFF
warrior7946
I NEVER THOUGHT TO CHECK IT AT ANY OTHER RPM EXCEPT HIGH RPM.I WILL CHECK THAT TOMORROW THANK YOU I WILL LET YOU KNOW WHAT I FIND THANKS AGAIN CLIFF
