I have a 1996 gas club car,I had some hesitation problems and narrowed it down to a dead cell in the battery. I replaced the battery and did a check to see if the battery was getting a charge...voltage at the battery never changed when run in test mode, so I replaced the regulator.....problem is that the old regulator only had two wires...red and yellow and a short jumper from the center bolt on regulator to the lower micro switch and also had another black wire in the harrness to the center bolt. The new regulator has yellow and red wires plus double black wires. Dealer said one black to the micro switch and to ground the other to the frame.I still had to put the black wire from the harrness to the center bolt or the cart would not start.In the end the cart runs but still does not charge to the battery.Any suggestions would help...Thanks
