I have an old Total Charger with a timer. After I plug it in, it will run for a few minutes and turn off. It will repeat this after I replug it in again. The battery voltage is above 36 volts and the relay appears to close to start up the charger. The voltage during the brief charging climbs to 39. The charging amps on the dial are about 18. I have used a 12 volt charger to recharge two at a time.
What are the possible causes?
