Charger Primary Coil Resistance?
clmanaa
I have 115 volt input to and through the relay which is clicking and activating but I have no charging. I've read for resistance on the primary coil with my meter on the 20M ohm setting and read no resistance. And just for the heck of it I checked for amp draw on the primary coil wires and there was none.
What should the primary coil resistance reading be?
Golf Cart Wizard
Check this out should cover all the powerdrive chargers:
The primary coil is an inductor, not a resistor. It is supposed to read continuity
Those relays are electronic relays. They are not Using a coil.
If the relay is kicking on then it's probably a bad SCR in the. obc. Jumper the big black wire to Pack negative and try it again.
