CC Regen being changed to Series
GolfCarDepotSC
I have a 98 CC Regen cart
and I am converting it to a Series cart with an Alltrax 400 amp controller and a Raptor motor. I installed an EZ-GO forward and reverse switch and a heavy duty 48v solenoid with all 4 gauge wiring. My next step is to use the original vglide setup but I have questions: There is a yellow wire at the bottom, then about 2 terminals up there is a purple wire, then at the top there is a white wire. Anyone tell me where these wires go on the alltrax controller? If I read the wiring diagrams, my guess is the purple wire to B- on the controller -- Yellow wire to #2 on the Alltrax and White to #3 on the alltrax. Am I correct??? My concern is the diagrams show purple wire as position #1 on vglide and Yellow as position 2. I opened up the vglide and that is not how it looks (yellow first then purple, then white) but then again, I don't know squat about club car. Thanks for the help
shadowman
i wish i could hepl you but i can,t whatever you do make certain about the wiring cause you don,t want to take out the new controller by guessing at what goes where.........my suggesting is wiring diagrams to make sure you get it right................................................
GolfCarDepotSC
After digging into the vglide some more, I felt comfortable in wiring it up. Purple wire to ground, yellow to #2, white to #3. Wow this club car runs so much better with EZ-GO parts on it!!
