Cart won't run !
Gunpowder
94 Mealist - stock everything but lift kit and tires/wheels. Riding my property and go to turn around. Backed up then it won't go forward. It has done this before but I keep mashing the pedal and it would eventually go. Any ideas what the problem might be?
Gunpowder
Yes and there were a couple that needed cleaning - I cleaned all of them - no problems since. Maybe that was it.
Andy4639
Take the F/R switch out and tear it apart and clean it up and make sure the contacts are making good connection. If there is any signs of heat replace the studs or whatever needs replacing.
