Cart suspension problem
jeffro22
have a Ezgo cart and am working on getting it running again. The cart sits low on the front drivers side. Is something that can be adjusted or fixed or do I need new springs?
There's no adjustment for height. New springs are the best way to correct it . You could put a spacer between the spring and the frame on the left side. If the left front spring is weak the left rear probably is to.
If you want to fix it right new springs all the way around is your best bet...
