Cart not running
officer1
Checked all connections and everything is tight. I get 38 volts at the resistors and when I push the pedel down it drops to around 7 or lower and nothing happens. any help ?
Thanks
divot61
sounds like you need to check each battery with a load tester, you'll probably find several batteries not up to snuff
