Car Stereo in '94 Club Car
eatdrinkadam
Folks,
Looking to install a simple car stereo setup in a '94 Club Car. (CD player with 2 speakers)
Is this process the same as doing a regular car? If not what specifics should i be aware of?
Just looking to mainline the stereo to the battery / ground, attach two speakers and be on my way.
Thoughts?
Otter
If I had a gasser I would wire a fuse block to the battery, I bolted my fuse block on the inside of the rear fender well, and then run all your 12v accesories off that fuse block. Make sure you use the appropriate fuse for the component though. Good luck.
eatdrinkadam
would an in-line fuse work for the mainline? Instead of having a fuse box.. since i only have one 12 v accessory being the stereo.
