cables getting red hot
christian
I have a 48 volt Club Car golf cart and the cables are getting red hot when just driving around the neighborhood. The motor and the controller has been urgraded, but I don't remember smelling hot wires before. I have checked all the cable to make sure they are tight, all good. Any idea's ?
Are you still using the stock 6 gauge cables? If so they'll get hot with the motor upgrade and higher amp controller. You should upgrade ALL the 6 gauge cables to 4 gauge or larger. Also make sure ALL the cable connections are clean and tight.
christian
The invoice from the Club Car dealer says they replaced the cables, but it doesn't say what gauge the cables are.
From what you descibe it sounds like they replaced the cables with 6 gauge. If you had the work done at a dealer I'd go back and let them know your having heat issues.
