Building a Lifted EZGO Shuttle 6. Need Help With 35 HP Briggs Install
pbillyi69
yes im sure you need one with a stronger spring. dont know which one i think they are color coded im pretty sure my was yellow. i put an 18hp with rev kit but could be talkin straight out my butt. Rod, Nubs, or DS will know for sure
pbillyi69
thats about right for the belt.....im sure you need a different driven clutch i just dont know which one. did you change any adjusment on the shift linkage?
roccoga
this is where i am glad this forum is here. i had shift linkage of when rebuilding cart. maybe it needs adjustments? i will have to check tomorrow
roccoga
I turned the idle down today.it helped a little still has a hard time switching from forward to reverse unless i play with the go pedal. i think the governor is messing with me top speed was 23. it only goes that speed if i start from a complete stop if not it is a slug maybe 10 mph. the linkage on top of the rear axle i removed when i put engine in is this something that is needed? The linkage that was hooked to factory governor? how do i check the driven clutch to see if i need the stronger spring? thanks for all the help. i sure makes me feel good knowing it drives.just have to work out a few things. oh ya header wrap is definitely needed.i only burned myself 1 hundred times adjusting things today:mad:
The linkage on top of the diff is just the road speed governor and not needed. is the drive clutch trying to engage at idle? maybe there is not enough slack in the belt, inside of belt could be rubbing on the bottom of the drive clutch? it will perform much better with the engine governor out of the mix.
I would be running a tach so you know just whats going on and when:twocents:
roccoga
Thanks for help and yes sometimes drive clutch was trying to engage now not so much it only when rpm is taking a while to come down. I would like to trash the governor so a tach will be in the future. Is there a linkage i could get that does away with this crazy set up?
Need to make up your own deal, I would try and live with it and get yourself a ATV style carb and 99% of those problems will go away:twocents:
That drive clutch is it? May need a different spring
That would work, make a adapter or buy one. May have to fatten up the idle circuit, reading the plugs will help dail er in.
