Building a Lifted EZGO Shuttle 6. Need Help With 35 HP Briggs Install
roccoga
Thank you again for helping. My wife and son want stacks like my truck so i guess i will run 1 /2 pipes to a muffler then to stacks? I wasn't figuring on running stacks but it isn't for me so I'll see what i can do. There are :):)all over my house. Wife even said spend more:thumbsup:
When the wife says go ahead and spend more money you're doing something right. :D
Keep up the good work and keep us updated on the build. :usa:
roccoga
I have been trying to find a machinist to bore this clutch.:( Sadly it is a no go. I do think i have found one that will work but it is pricey a comet 1190. I did get the wire harness ran for ignition, ran row of toggle switches for lights, got gas pedal linkage working as well as choke. Oh ya i went to tractor supply and bought a roll of 1/4" rubber and made new floor mat $35 was a deal I think. I have to order clutch and get exhaust made and it should move!!
roccoga
is there any way of switching from drive to reverse without shutting engine off? its real torque but doesn't seem super fast could this be governor?
pbillyi69
you shouldn't have to shut it off to change gears. did you change the driven clutch to one with a stronger spring?
