braking down ezgo engine for rebuilding
it seems that we all like pictures and maybe somebody wants to know whats inside. its kinda boring stuff
this dirt build up will over heat a engine quick, very common on this engine.
ever wonder what the white wire was for that was never hooked up, its for a low oil shut down or low oil light. this is the sending unit for it
this is the pulser coil
more dirt
very common wear point and should be checked
make sure you mark the rotors on the oil pump so it installs in the same location otherwise it may not build pressure after your done. sorry for the bad picture
