Better Headlights for 36 Volt Golf Cart
rodder98
Our 1995 EZGO TXT is a very good golf cart, but the headlights are kinda poor. Do you have any suggestions for installing headlights that provide better vision?
If your EZGO is a 1995 it should be a Medalist model with a metal body. What type of headlights does your EZGO have now?
rodder98
It seems like it is probably the standard OEM lights that were installed when it was built. Nothing special at all.
Are you sure the lights are getting 12 volts? I'd check that first, it's possible they're running on 6 volts. They make a light bar that mounts under the front bezel but normally the standard lights are brighter than than the light bar. I've seen guys run both.
