battery trouble
twaig
I have a 94 marathon that converted it to 48 V and using seperate 12V with the 36V. The batteries with the 12 V charger connected to it only charges to 65% changed the batteries to two new ones and same thing is occurring. tried charging individually using 6v mode and same thing no more than 65% any ideas???
thanx
twaig
Are you sure there's not a problem with the 12 volt charger? How do you know the two 6 volt batteries are only charging to 65%?
twaig
the multimeter is fine. rest of the batteries read 6.1-6.5. I used two different chargers. one of the chargers have a 6 volt charge setting on it where it also tells me percentage of battery. I might have to disconnect all accessories and charge the batt see if that make a difference. the wiring is setup like yours gorno. worked fine for 1 year then now it acting up. could the batteries be losing power (drain) somewhere. It drained fast and almost left us stranded.
thanx
Craig
gornoman
Well-Known Member
Forget that scale and take voltage readings on all 8 batteries one hour after a full charge. Post the results.
