Battery tray problems...
afonda
Hi all,
I have a 2001 CC 48 volt.
The battery tray is really wierd looking. the aluminium tray that holds the batteries is getting corroded with oxidation and it actually looks like the aluminium is splitting open in layers along the front edge where it supports the 2 center batteries..
I have temporarily bolted in a piece of plywood to support the right center battery.
What is happening and how do I fix it?
how do I fix the tray?
JRay
You could pop rivet some aluminum angle in there. I have heard there is a kit you can buy to repair that. Someone on here should know where to buy one.
wildthing
sounds like the battery tray is corroding from the battery acid take the batteries out clean the trays with baking soda and water and a brush put a brace along the edge of trays or maybe replace them if they are real corroded and worn
