Battery problem
bobking44
2002 Western (EzGo) series cart running on 42 volts.
Batteries 2 years and 4 months old.
Providing less than half the run time they were two months ago.
The drastic change came on suddenly.
I fully charged the batteries (Trojan 105) last night and let them set for over 12 hours.
The SG is now excellent and equal in all cells
The voltages range from 6.38 to 6.43 across the battery pack.
Last even when cleaning the cable connectors and terminal posts I discovered the light/horn circuit was drawing current when all accessories were off. I did not measure the drain but it sparked when reconnected and that sparking was followed briefly by a humming or buzzing sound that lasted for about t seconds and then there was silence. I pulled the fuse on the circuit and left it over night to perform the test that provided the results above.
To your knowledge, is the sparking and hum of the lighting system normal?
If so, what is the cause?
If not normal, do you have any suggestions as to what the problem may be?
With regard to further testing the batteries, am I correct in assuming a load test to determine whether there is a bad cell is the next step?
If that is the correct next step is there an inexpensive way to perform such a test and what might that be?
Thanks so very much for any help you may be able to offer.
Bob
Two things you can do to find out more about the batteries. Take individual voltage readings on them under a load, while driving the cart. Take individual voltage readings on them once you notice the cart slowing down. Post the results and we can tell you if you have a bad battery.
bobking44
Thanks. I will try to get those readings posted tomorrow, but my schedule is heavy and it may be Thursday before I can get it done.
Thanks again.
Bob
