Battery not charging
jharmon
I have 2002 gas club car and appears the battery is not charging. I can charge the battery and it will crank and run for several rounds of golf before it goes down and has to be recharged again. How does the cart recharge battery? Starter generator? Does it have a voltage regulator? What might be my problem?
Batman
The starter is also a generator. Yes the cart does have a voltage regulator. You should check the regulator. Its common for them to cause the problem your having.
