oldcartfart
hi' I just finished putting an 85 ezgo back to running condition. I have a problem that is new to me,i put 3 12 volt marine batteries in to check the cart out as i always do when i finish one, but on this cart when i left it sit overnight with the key off F/R switch in neutral in the morning it shuddered when i pushed the peddel down went slow picking up speed but not like the day before. i charged batteries it took less than a 1/2 hr.to charge then it worked alright same thing the next day. i unhooked the batteries let it sit overnight hooked the cables up in the mornig no problems took right off as it should. i only use 3- 12 volts to check the running cond. when i'm putting one back together. the batteries are less than 2 months old and are holding a charge well. i've checked all wiring connections they are clean and tight. i have let the cart sit for 2 days in a row. and it wont go without charging it first.the only thing i can think of is possibly the brushes in the motor. or a sticking soleniod. with key off i get no light on my 12 volt tester. any ideas on what i shoul check next? this is a new on me. thanks for your time. OCF
