chasenfish16
At what amp should a powerwise battery charger shutoff? My charger only seems to charge for about 3-4 hours and then kicks off at about 10-11 amps on the ammmeter on charger. This seems to be alittle high to me after reading other posts that say it should go down to about 5 amps and stay there for a while before shutting off. I am just concerned I am not getting a good topping off charge. By the way the batteries are 2 years old and I have checked each cell with a hydrometer and also load tested them all and they check fine. When the charger does kick off and I check the charge about a hour later the voltages are what the state of charge sheet says they should be. Any suggestions?
