take the main neg. cable off 1st......should be driver side front battery and tape the end up so if it touches anything, than the main pos its pass side front battery same thing.....than you should be safe as long as you are careful with your battery wrench you know don,t go shorting anything......when you hook back up same thing after all cables are on than do the pos 1st and the neg is very last one..................just take your time and be careful.........make a diagram if needed................................
