Bad Fuel Pump?
huntr
2001 Workhorse
Cart ran fine 3 weeks ago.
Went to start it last weekend and it won't fire.
Looks like it's not getting gas (need to disconnect the hose to the carb to double check).
Fuel filter almost dry, no/little gas moving from tank.
Do the fuel pumps on these go bad very often?
What else should I check?
i would confirm if its pumping to the carb, the filter seldom fills very much. is the cart in cold weather? a little water in the gas will freeze in the pump.
