3B$
Hello,
If anyone has a functioning 2010 48v Bad Boy Buggy 1500E MTV 4x4 with electric dump bed using the Navitas TSX500-BBM controller, I could use some photos of the wiring on both sides of that harness plugin to the 48v harness showing all the color of the wires in relation to each other.
Mine are chewed off at both ends so I have no idea what marries to what, they are not all the same color which was probably done to keep it proprietary. If you could also include pics of the inside under the seat showing all connection points, fuses and relays it would be greatly appreciated, with that I should be able to wire it back together and ensure all cables including the batteries are wired correctly and test it out.
I cannot find any wiring diagram for that controller and wiring harness on the internet to date, thanks in advance to any that can help out.
