Bad Boy Buggie Wiring Help
Bodine
While checking fuses behind the dash panel on my 48 volt Bad Boy Buggie I managed to pull loose the yellow wire from the voltage indicator and need some wiring help. Seems to have pulled out of a butt connector as the wire end is clean but I don't have a clue from where. The connectors in pic are only ones near range of the wire. I dont want to guess and burn something up. Thanks in advance.
Bodine
Everything works but factory headlights, those splices are for ad-on headlights. I originally removed dash to check fuses and run voltage tests, while diagnosing a no run problem that proved to be failed solenoids. I had to pull dash again because the reverse wire came off directional switch and found this loose.
Bodine
No they have not worked in ages. This wire goes to the voltage indicator between the on/off and fwd/rev switches. What I dont know is where it feeds from
If it's the wire for the voltage meter it should be connected to either the key switch or to the battery pack. I'm taking it the voltage meter was working and now it isn't?
Bodine
HotRodCarts ty for your input. After opening up looms and finding nothing, I removed the key switch and it appears to have a missing terminal on the back. I touched the loose wire to the yellow wire on the switch, turned switch on and the meter lit up. I spliced it into a new female terminal with that wire and all is good In the buggy world today.
