axle bearing
Welcome to the forum.
There's a snap ring on the outer end of the axle at the backing plate. Remove the snap ring and you can pull the axle. I believe the bearing is pressed on the axle and you can remove it once the axle is out.
Glad you git it fixed.
tunnelmike
Would this process be the same on a 95 fleet? Can you get the bearing at an auto part store ? Drivers side started making noise on the way in the woods this am. Thanks for the help. Mike
