best answer is every time you put gas in it look at your oil level where you add it in the resivior.......if its not clear plastic that you can,t see the level just take the cap off and look if its low it won,t hurt to add and for those of you who are unaware it won,t hurt to also just add some oil to your gas tank, if your full and you use regular 2 cycle dump 10 ozs in will make the difference if your auto oiler quits working and you don,t find out until engine seizes up that oil you added in tank just might save that engine...........only drawback is a little smoke possible i say possible cause lots of carters who do this notice no smoke at all...................................................
