mdtjewelry
while trying to figure out why the cart goes when the pedal is no pressed i foung that the ball joint had slipped off, but even with it manualy pushed all the way forward the cart still goes. I noticed some arcing while i had the seat off and was easing it into gear from behind the forward/reverse switch. there are also 2 tiny wires hanging out. How can i figure out what these wires are and where do they go? And could this be the solution to my problem with the cart going even with the key out if you put it in gear and arent pressing the pedal?
