ACEGOLFCARTGUY
I have a 94 1500 and the trans is slipping bad in the lower gears. I found this one used on craigslist but not sure if it will fit. I went to Oriellys and we are confused because the computer shows his 93 transmission should be a 12 pin and not 13.
His truck is a 93 Chevy 2500 350 engine automatic 2wd 4L60E tranny.
Mine is a 94 Chevy 1500 350 engine automatic 2wd.
How can I find out if my trans is the computer controlled 4L60E or just the 4L60? What are these pin plugs anyway? Thanks!!
2nd question I wouldn't mind doing a little work to change this truck to a 4x4. I found a 94 Z71 parts truck with a 700R4 tranny and transfer case for $300. Will this 4wd transmission bolt to my 2wd engine and then later I can put a solid axle in the front?
