Hello everyone,
Add me as another that has a PowerDrive charger that does nothing when turned on (after being plugged into the cart) !
(48v)
Bought the CC used , put in new batteries, Charged up and seemed to work fine, charger came on after a short delay and hours later was at a trickle charge. All good so far.
I'm away on business for 3 weeks, wife calls and says batteries are not charging, I read the posts here and another site and check the batteries when I get back. Voltage is 3v or less in each battery.
I looked at the posts that suggest there is not enough voltage to trigger the charger and its possible to bypass that circuit. They refer to different connector numbers..where do I find those numbers, I'd hate to put the wrong wires to the wrong posts....
Any help will be greatly appreciated!
I did by the way check the fuse under the seat that is in the yellow weather proof holder and it was good.
thanks in advance
(48v)
thanks in advance
