newvisionss
thank you for your imput. I reset the valves, the right way this time. checked the compression at full throttle. 142 and 144 pounds then started it it ran like a bat out of hell for about 1 minute, then when I let up on the trottle spit oil and gas into the air cleaner box and so much it sucked some in the carb and died.... so I drained the oil. let out about two quarts, heavy in gas probable 50/50 oil is a guess. so then in my thinking it had to be coming back from the fuel pump. it is hooked up correctly, but I couldnt really figure out how to tell if gas was backing into it with it off. so I hooked up a makeshift tank and it ran fine for the few minutes that i had gas. NO blowback through the vent tube at all........ so am i on the right track with the pump??? can it be rebuilt or do you by a new one? I took it apart and looked at it simple rubber valve looked ok.... please advise thank you
