couple of questions on 5 inch lift from allsport. ive got the lift installed fixing to set toe in should there be tie rod extensions or do i not need them this is a 2002 txt ezgo. also i did not use the longer shackles on the rear because the cart is sitting level without the longer shackles are there any disadvantages when not using them
