Accelerator micro switch??
dirtman
OK....on a 84 gas CC....I had to put a new accelerator micro-switch on because the cold temps. cracked the plastic and broke the old one. Here's my question. How does the open /close circuit work on it with it being open when you apply the brake...(thus shutting engine off) and also being open when you apply the accelerator pedal about half way? Am I adjusting it wrong?
The micro should activate as soon as you start pressing the throttle and stay activated/closed through wide open throttle. It should open just before the throttle is all the way up and just before the butterfly fully closes on the carb.
