GarageBuilt
Well-Known Member
I blew up a new high voltage controller.. The controller will shut it's self down anything past 250-volts... The controller was rebuilt at no expense to me nor was any questions asked... But to be fare I am looking for any dead shorts... Now my total voltage is 200 volts... Ok so if I had a 200 volt short in my system where would it show up at... I have 200 volts coming from the battery pack.. The same amount going into my main contacter & coming out once it is closed... I have pack voltage going into & out of the controller ... And the same for the motor... My frame is clean... At the most it has .5 volts on it..The controller blew under a load around the 60 ft mark.... After blowing two of the same controllers both the same way now I am gun shy.. I find myself not wanting to pull the trigger ... The new controller is installed & ready to go... I just need to hunt down all the butt puckering adventures !!!!!!!
Please tell me what you can.....
