99 club car not turning over
insane biscayne
99 club car not turning over push the gas pedal solenoid clicks but dont turn over ran fine the last time out checked oil took big white wire off the starter gen and jumped it to the battery and still nothin any suggestion would be greatly apperciated
Welcome to the forum.
Whats the battery voltage? If the battery is good try jumping the two large posts on the solenoid and try starting it. If it starts replace the solenoid. If it doesn't it may be brushes or another problem with the starter/generator
insane biscayne
ok i tryed that and nothing happens it dont even make a little spark when you jump the wires so i guess i will try brushs i will let you know what happens thanks for the reply back
shadowman
are you sure your battery is ok? thats all it takes...............there are rubber plugs you can take out to check the brushes but a 99 i think you,ll find them ok............make sure your battery is ok under a load................................
