97 EZGO Rear End Diagram
ACEGOLFCARTGUY
I need a parts break down diagram for my gas 97 EZGO rear end. I have the right axle and axle house pulled off the differential, but I can't break the diff case apart. Do both axles need to be out?
What I am trying to do is take 2 bad rear ends and make a good one. One of them is able to switch gears from forward to revers but the axles will not spin.
The other rear end spins the axles with the clutch but will not switch gears, its jammed. Also this one has a bent input shaft. I may just replace the broken pieces instead of scrapping one rear end for the other...depends how much input shafts are.
