96 ezgo nogo
ftfixer
I HAVE A 96 EZ GO THAT HAS NO SPARK I HAVE TESTED COIL,IGNITOR,PLUGS ,STATOR, MICRO-SWITCH ,IGNITION SWITCH,FUSES,FUEL,CARB,SOLENOID ALSO ALL CONNECTIONS AND ADJUSTED VALVES. I TOOK CART OUT AFTER COLD MONTHS TO PREPARE FOR SPRING AND SUMMER CART DID START 1 TIME FOR ABOUT 30 SECONDS AND HAS NOT RUN SINCE AND DO NOT KNOW WHAT ELSE TO DO. ANY HELP WILL BE APPRECIATED.
COPB
First thing to check is the engine ground. Wrap a wire around the base of the plug and ground it to the battery.
I never heard of a test that you could do on the ignitor! how is this done.
ftfixer
my bad i did not actualy check the ignitor my son has a cart exactly like mine i swapped the ignitor from one to the other
ftfixer
thank god i finally got this cart running i had all connections and components checked out by an auto electric friend of mine and he must have been having a bad day or either did not spend much time on it. i went and picked it up and found the starter was wired backwards and cables were connected to solenoid backwards among several other mistakes anyway checked it out while on vacation and found that the ground wire coming out of the ignitor only had 1 small wire still connected.replaced ignitor,removed carb. cleaned drained fuel,adjusted valves and started her right up. spent a lot of time on this forum viewing threads from a lot of different folks and really do appreciate the help. now my wife says leave the cart alone and stay off the computer so much and i promised her i would not do either one because both of these have become good hobbies for me even thouh at one time i was ready to get rid of my cart. thanks again
