Hello....Newbie here. I did a search about clutches and read all I could find on here and I need more help. I have a 1996 Club Car with a FE290 engine. I have the engine out on the bench. I made a puller for the clutch but when I pulled it only the spring housing came off. Then I was able to remove a snap ring and the outer half of the clutch came off, then a spacer and then a bearing. I still have the inner half of the drive pulley and the starter belt pulley on the crankshaft. I don't see any set screws. There are 3 bolts between the starter belt pulley and the crank housing that screw into the inner half of the drive pulley and I loosened them but no help. How do you get the remainder of the drive pulley off the engine crank? Any help would be greatly appreciated.
Thanks!!!!!
Thanks!!!!!
