I have 96 CC 48V - I replaced all cables, new AXE controller, HD solenoid, HD F/R switch with new Microswitches. Hooked everything up but it only goes in Reverse no matter if the F/R switch is set to F or R.
I have studied the wiring diagrams to be sure I have run wiring correctly plus tried switching a couple of connections but still the same result.
Also, interested in the previous comment about removing the OBC. I was curious if that might be the source of my issue? What does removing the OBC accomplish?
