96 4 stroke won't start
maphil0847
96 EZ-GO 4 stroke abruptly stopped starting. There is about 5 volts output on the B solenoid terminal when the pedal is depressed but the starter doesn't turn. Hooked a jumper from ground on battery to starter and it will crank but there is no spark. Help please??
First off that’s not enough voltage Have you tried hooking up another battery?
Wait I re read your post. Check and make sure your cables from ground are really clean. Check battery voltage at the battery. Let me know what you find. I’ll try to help.
