95 ez go has not been running for about a year i got cart running last night had 1 bad plug wire,took carb off and cleaned,crank case vent line was broken and fuel pump was not pumping after priming it started working ok only now i can not get it to level out and run with out skipping and backfiring through the carb. what do i need to look at next.the guy who owns the cart said a friend had tried to get it started but did not have any success so it had just been sitting. i also forgot to mention that i adjusted the valves and it seems to have good compression. i have driven the cart but it just does not run very well so any help would be appreciated so that i can get paid.
is it starving for gas? if so it is still carb blockage, go through the carb again, if you can force feed with gas and it keeps running it is in the carb
