95 DS Golf Gas Cart Sat for a Year and Someone Jumped it with Connection Backwards
Chipsta040365
Thank you everyone for welcoming to the forum.
Key and pedal press did nothing after a family member tried to jump the cart, but, had the wires reversed and of course sparks went everywhere.
Figuring most of the electric components were blown, I have currently replace the Solenoid, voltage regulator and all 4 micro switches.
I now get a subtle click like a micro switch when I step on the pedal, not the clunk you would expect from the Solenoid.
Battery is good and has 12.69 volts with key on and lights on.
If I jump the Solenoid the Motor cranks but does not start.
What else should I check/replace?
Also, I plan or replacing all the wiring, there is at least 12 misc wire splices throughout the old harness.
Any an All advise is greatly appreciated!
Thank you
Chip
Quick update for anyone following the thread...
  • replaced all the wiring with correct color coded wiring.
  • replaced all the microswitches
  • replaced solenoid and voltage regulator
  • drained tank, and found the old gas cap fell apart and was blocking intake tube - fired up, but ran bad.
  • new carb
  • new spark plug
  • oil change
runs like new again, amazing how simplistic the design!
Now on to the Mods! :)
