95 4 stroke ezgo
ftfixer
black smoke and gas fumes from engine i have adjusted valves and also took the carburator apart and cleaned and installed new plugs maybe a different type plug or what do i need to look at next.
Did you remove the carb to clean it and blow it out with a compressor after cleaning? Did you check the float? It should be level when it's all the way up (needle closed). Check to make sure the choke is opening all the way. What kind of plugs did you use? Make sure your air filter is clean...
ftfixer
i did take the carb. off and disassembled cleaned with carb. cleaner and compressed air the float is working correctly i will check the choke tomorrow and also the name brand of the plugs do you reccomend any plug in particular.also did you ask if the choke was opening or closing all the way. will get back to you tomorrow.
ftfixer
replaced the plugs with ngk and made sure the choke was adjusted correctly the plugs that i removed were autolite and both were very smutty but not wet. i operated it for probably 5 miles on road and in woods seems to be doing a little better but can tell more about it in the shop tomorrow when i check the plugs again. i will follow up later been working so it took me a while to get back to you. i will follow up later.
